Salta al contenuto principale
Repair and disassembly guides for desktops manufactured by Acer.
70 Domande Visualizza tutte
there is no sound on my incoming text messages
hi, i'm getting text messages without sound so i have to be checking constantly if i have a text cos there is no sound when they come in. I have checked all the slides and they are way up, the volume is on full too.
i will appreciate any help,
thnk you so much
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Check Sounds tab Sounds in Control Panel. The sound for text notification should be enabled and you can also select a different sound. You can test if this is making a sound by clicking on the Test button. If you still do not get sound notifications then check your notifications settings to verify that sound is enabled.
Punteggio 0
Aggiungi la tua risposta
eddyv101nj sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,324
