Salta al contenuto principale
Repair guides and support for the second generation Honda Insight.
Why do the electric passenger windows quit working?
How can I fix the problem of the passenger windows when they stop working. The drivers window works fine but the other three windows suddenly stop. Is there a part that I can replace and what is making that part die?
Questa è una buona domanda?
Punteggio 0
1 Commento
Does the drivers side switch operate the window on the passenger side?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There are many reasons the widow wont work . It could be the regulator , the electric motor, the switch on the passenger door , the switch on the drivers door , but the most common problem is the wires in the door were they pass through the door hing . as the door opens and closes the wires flex and bend and eventually break . Your best bet is to get out your multi meter and do some testing .Hope this helps
Punteggio 3
Aggiungi la tua risposta
William Salzwedel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 450
