Salta al contenuto principale
2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor
106 Domande Visualizza tutte
Broke the HD sensor connector installing an HD, Will this harm mac?
After helping many people upgrade their Mac Minis HDs, Memory, and other things, I decided to put an SSD in my Mac Mini. While removing the HD temp sensor plug (clip) the whole thing broke broke off the Sata daughter card that holds the HD and optical drive. Will it hurt my mac mini to run with the fan on full tilt? I use this as a server in a closet so the sound is not bothersome. If it is bad to run it this way, where can I find that daughtercard for a reasonable price to fix this. Thank you for your help!
Questa è una buona domanda?
Punteggio -1
1 Commento
Would you please post a picture of what remains on the daughter card?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
According to EXACTLY which machine you have (please give the last three letters of your serial number), you can solve your problem for about $30. The interconnect board, Apple part # 922-8807 needs replacement:
UPDATE - Thanks for the update on which machine you have. Your part number is 922-7320
Do a web search for that number. They can be bought for $9.99 on eBay.
Punteggio 3
2 Commenti:
Apple Mac mini "Core 2 Duo" 2.0 (Early 2009) Specs
Identifiers: Early 2009/NVIDIA - MB463LL/A* - Macmini3,1 - A1283 - 2264
da
The serial number last three numbers / letters are 1BU . Thank you for your help!
da
Aggiungi la tua risposta
Ben Parkhurst sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,379
