Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Does this iPhone 6 power ribbon look like it will still work?
I was replacing the battery in a cell phone as a small project and I accidentally struck the power button cable with a butter knife (high tech, I know). Visually the copper itself looks intact, however the material that the ribbon itself is made out of has been rubbed off. From its physical appearance, does the cable look like it needs to be replaced?
Here's the link to the picture: https://ibb.co/bvD0D8
Questa è una buona domanda?
Punteggio 0
3 Commenti
you would need to add a photo for anyone to give you an answer
da
I added a link because I couldn't directly insert the picture.
da
should be ok, just put a bit of electrical tape over it before putting the battery in
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Based on your picture, it doesn't appear to be damaged. The black coating is very delicate and scratches off very easily but as long as the integrity of the traces is good, then your fine. You could put a small piece of Kapton tape over it to insure that nothing gets shorted when powered.
Punteggio 4
Aggiungi la tua risposta
Taylor Hinkel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 115
