Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
iPhone 6 - screen replacement - no auto-brightness - laggy screen
I replaced the screen on my iPhone 6 with the iFixit iPhone 6 LCD Screen and Digitizer Full Assembly. Since the replacement, my phone no longer auto-adjusts the screen brightness and the screen has become very laggy, sometimes causing the screen to freeze, sometimes opening things I didn't touch, and sometimes not recognizing my touch at all.
I took the phone back apart to make sure all connections were reseated properly, however the problem persists.
I tried to remove the front facing camera and ambient light sensor from my original screen in hopes of replacing that part of the replacement screen, but the ambient light sensor disconnected from its cable in the removal process, so that is a no go.
I never had either of these problems with the original screen. Is this happening because my replacement screen is faulty?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes the screen could be faulty for the random touching, no touching, and freezing. However, for the auto brightness that is dealing with the proximity sensor. Make sure the sensors are seated well into the screen. and look for any damage to the proximity sensor flex cable. If there is damaged you can get a replacement for $7-$15USD on Amazon. But the screen is a bad screen you need to return it and get a different one.
Punteggio 0
Aggiungi la tua risposta
Emily Resner sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 183
