Salta al contenuto principale
Lanciato nell'aprile 2010 / processore Core i5 2,4 o 2,53 GHz o Core i7 2,66 GHz
590 Domande Visualizza tutte
I dropped my MacBook from 50 cm height
help, i'm really freaking out, i accidentally dropped my macbook pro unibody 15' inch, procesor 2.4 Ghz intel i5, (just 6 months old) i dropped it with position left first, it's startup just fine, but then i realize, theres bump, and scrapping, but what concern me most is the bump that shape like small circle in the upper left of my speaker (the lid is closed when i dropped it) and i realize the back lid (where the screw are attached) is like missplace, i almost can see a gap there, i try the power adapter, the battery, usb port, ethernet, startup disk( i turn it off and on several time) verivy my hardisk, trying every key, lcd , speaker,and back light, but it just work fine too me.. no weird noises, but i still freaking out especially strange bump/dent that shape like circle.. i'm afraid there's long lasting damage, wonder how much will it cost (i'm just a freelancer)
what should i do.. answer pretty much apreciated.. thank u :)
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Besides the bump and scratching, it sounds like your machine is fully functional. If you are a real stickler and the bump bothers you so, then replacing the bottom case will solve that issue. But replacing the bottom case is a daunting task for someone with no repair experience. Getting it fixed professionally is going to cost you an arm and a leg. I would say leave it be if the machine still works normally.
Punteggio 4
hey man i have the sam proble i have to upload some pictures....now i have a problem with the left side on the display
Punteggio 0
Aggiungi la tua risposta
shieny sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,760
