Hi Minho!
Your posts always help, thank you!
I have a cuestión about iPad Air 1 and 2.
I got now 3 iPad Air 1 and 1 iPad Air 2 with the same problem but no solution.
I will give details for iPad Air 2 because it is the one we did all:
5V coming in U3500 OK
3V going out on PP3V0 OK
1.8V going out on PP1V8 OK
3.73V on PPVCC_MAIN
I checkout all outgoing of PMIC U8100 and ok.
Getting near to battery I checked L8812, D8800 and Q8804 as you recommend and PPVCCMAIN is ok on them.
Now the problem. On Q8804 we have same problem on all of the 4 iPads. PPVCC_Main is coming in well on pins 1-3 but PIN 4 has same value as PPVCC_Main so on PINs 5-8 the valué is always under 1A.
We even replaced the PMIC which is controlling Pin 4 . All PMIC valúes still perfect but Q8804 still does the same.
Can you help us with this please?
greetings and thank you very much
Stefan
Votato
Annulla
Punteggio
0
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
