Salta al contenuto principale
Guide e informazioni per la riparazione dei controller Joy-Con di Nintendo Switch.
167 Domande Visualizza tutte
After opening the Joycon, it works only attached to the switch.
The thing is: I messed it up.
I tried to put a transparent shell on my joycon and the right one now can only work attached to the switch. I've already cheked the battery and it's working fine.
I think it's something related to the motherboard, but I can't tell for sure. Someone here have a better understanding about the joy con circuit?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Cheers mate.
Not sure if it's the same issue I had, but in my case the SL button wasn't connected to the joy cons mainboard. That's why I couldn't use it in horizontal mode, but attached to the Switch.
Hope that helps.
Regards
Punteggio 0
1 Commento:
Hello!
Actually I've already sent it to the repair support. According to them, anything could have caused this, but unfortunatelly it really was a motherboard problem. I don't know how I managed to break it, but I just had to use another Mobo and now everything is working fine.
da
Aggiungi la tua risposta
kleberlauton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,200
