Salta al contenuto principale
Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
494 Domande Visualizza tutte
Excessive oil filling air box from crankcase?
I have an easy go TXT gas golf cart with the Robin engine in it. I am getting excessive oil from my crankcase breather in to my air cleaner air Box? When it gets warm, I get Oil from my crankcase breather, up the tube and into my air Box, then into my carburetor causing a ploom of white smoke? Is my crankcase breather vent bad? When i soak it up with a rag it runs fine until it gets warm and does it again?
Thank you in advance for some info.
Tony.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
I used to have a motorbike that did this. If your airbox has a drain tube in it. Unplug it and clean it out. It should dribble out merky oil. But they usually sludge up.
Punteggio 1
@ducatikid999 your engine should have a PCV valve. Replace that first and see if that helps.
Punteggio 1
2 Commenti:
BINGO!!~ You just got it. 500.000 + Congratulations ;-) @oldturkey03
da
@mayer thank you Sir. Couldn't have done it without your support over the last 8 years!!!!
da
Aggiungi la tua risposta
Tony sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 52
Tutti i Tempi: 5,039
