Salta al contenuto principale
Dishwasher by Bosch identifiable by the model number SHU5315UC-06 or SHU5315UC/06.
11 Domande Visualizza tutte
led display and lights do not work
Have a Bosh logixx dishwasher, It will function by the power button. So will do the job and turn itself off etc........It is meant to have a count down timer on the led display etc but the display and lights are not working.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Have you tried to dissemble it and check pcb? Connectors and fuses especially?
Punteggio 0
1 Commento:
I could not find a manuel guide with a picture...do you know where the fuse are located?
I was thinking it could be a fuse but also need the type of fuse
da
no replaceable fuse on this unit . check connections from the pcb to the lights or replace pcb
Punteggio 0
Aggiungi la tua risposta
Mark Marriner sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,112
