Salta al contenuto principale
Il Game Boy è uscito il 21 aprile 1989 in Giappone, seguito dal Nord America il 31 luglio 1989 e infine in Europa il 28 settembre 1990. È caratterizzato da un grande involucro grigio e dal numero di modello DMG-01.
71 Domande Visualizza tutte
Crooked screen and missing center lines
I have an original game boy and recently I changed the body. I believe the problem existed before.
The screen appears to be not aligned with the body and in addition has two white lines in the center. What may be due?
Could it be the video connector? I have already tried to enter it several times but the screen remains not centered.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
The vertical lines are most likely due to connections with the data ribbon leading to the screen.
I've often seen it happen to units that were left in hot cars or attics.
Here's a great guide, from RetroFixes.com, that will, hopefully, help return the screen to normal ...
Once you have the unit apart, you'll be able to line up the screen again. Just be sure to verify that it's straight before completely screwing it back together.
Punteggio 0
Aggiungi la tua risposta
Ivan Meo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 940
