Salta al contenuto principale
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 Domande Visualizza tutte
Simpler battery replacement process?
Could the process shown at iPod Nano 1st Generation Battery Replacement be simplified at step 7 by simply cutting and stripping the wires and soldering new battery wires together and covering with heat shrink tubing? This would remove the requirement to disassemble the logic board, thumbwheel and front face of the iPod nano.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
That's a little too ghetto for iFixit.
The whole point of that guide is to remove the logic board so you're not messing with any of the other components while using the soldering iron. iFixit presented the safest option. I wouldn't recommend that people follow your advise (even though it sounds feasible) just because it's kinda of jerry-rigged.
If you want to take a step further, you could technically just follow the soldering steps without removing the board. I do NOT recommend that. There's no reason to use heat shrink tubing at all.
Punteggio 0
dont know if its the battery how do I identify the problem
Punteggio 0
1 Commento:
matthew, it would work great for you if you post your own question. Click on the link on the right side of the screen "Ask a question" and give as much detail as possible. Like what device, what problem. has it just happened, anything you were doing just prior to? Need more info than the one sentence you posted as an answer to someone elses question ;-)
da
Aggiungi la tua risposta
fredvandenhout sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 942
