Salta al contenuto principale
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 Domande Visualizza tutte
Why is my computer crashing randomly? (blue screen) Boots into Bios?
Hi My Asus Laptop recently started to crash randomly, its not an old laptop, It can go anywhere from a few days to a few seconds and crash. It sometimes boots into bios, and sometimes boots into windows 10. I ran malware bytes and came back with nothing, ccleaner, cleaned the registry, temp files, disk cleanup, defrag, just got done doing a reset and its still crashing. Any help would be appreciate. thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
What do you get when you go into the event viewer after a crash ? May be a good idea to run a mem test .Bad memory can cause crashes . You can also check your system files with a sfc scan Check your exhaust fan to make sure theres a good flow of air . An overheated computer is prone to crash . Just some ideas that may help
Punteggio 2
1 Commento:
I will do all those and get back to you with how it works, thanks! I never thought about the fan thing. Definitely going to Check that out.. its loading into bios currently i gotta wait til it loads windows...
da
Aggiungi la tua risposta
emason34 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,074
