Salta al contenuto principale
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
What could be the knocking noise coming from the engine area?
There is a knocking sound that started coming from my car a couple days ago. It's not a ticking or a clanking knock. It's more of the sound when you take your fisted hand and starting from an inch above a wooden desktop tap at about 1 knock per second. (It's more of a deep and slow, soft knock than most of the sounds I've been hearing while researching online).
To add, I have had a problem with coolant leaking from the thermostat housing gasket—well there was no gasket. We replaced that, and now it doesn't leak—but the coolant is still going somewhere. I don't know where yet....
Any ideas on what the knock is and possibly where my coolant is going? And what fixes do you think would be best?
Thanks for any suggestions. :)
Questa è una buona domanda?
Punteggio 3
4 Commenti
Just put in a new radiator in my 1997 jeep, due to overheating and had a leak. I took it for a ride and still over heating.So I took the thermostate off and now its leaking from the exhaust!!HELP...Any suggestions
da
I have an 03 and i replaced the starter solenoid relay because it wouldnt start made it to work later on when i got off no start made sure all relays had good connection and tried again it kinda dragged to start and when it did its now making a ticking noise and worsens when i accelerate . help. Someone please
da
Check where the starter connects to the flywheel there is a plastic shroud sometimes they warp and the flywheel hits it replicating the sound ur describing u can just take it off if it is that it wont hurt anything as long as ur not off roading or trying to stck ur hands in there while its running
da
I have a 2014 Jeep compass 2.4 liter took top of engine apart were cam shafts are no apparent problem there but there is bad engine knocking in it added Lucas additive a week ago it was quit now it's super load
da
Aggiungi un commento
8 Risposte
Soluzione Prescelta
Sue, I'm not sure about your engine size, but the 3.4 engines are commonly known for intake gasket leaks and the 3.8 is known for the intake manifold going bad. If the noise you hear is a fast tap or clatter near the top of the engine, it could be valve noise which would require you to have some cylinder head work done. Some noise can come from a worn camshaft. It's also a tapping noise. If the noise is a steady metallic rap, it may indicate a rod/rod bearing. A quick steady tap may indicate lifters or cam lobe, while a clatter may be loose/worn rocker arms. A low rumble or knocking noise could be caused by a bad rod bearing on the crankshaft. Here are a couple of sites that will tell you a bit more:
As you can tell, there is a multitude of problems that can come with that noise. Try to troubleshoot a little at a time. Check your plugs and see what they look like at the business end. You can get a lot of info from that also make sure your oil and coolant levels are okay. Maybe get somebody to do a compression test and a leak-down test to see if your valves/rings etc. are okay. What do your exhaust fumes look like? White smoke? Black smoke? White smoke could indicate that some of your coolant gets into the combustion area, while black smoke suggests excessively burning oil. Good luck to you, and I hope this helped a little.
Punteggio 12
4 Commenti:
+ really excellent answer The coolant is probably going out your tail pipe in the form of white smoke. You may have a vacuum diaphram allowing coolant to be sucked into engine such as heater control valve. Antifreeze and water do not combust and will cause knocking. Did the engine ever freeze after running out of antifreeze?
da
Incredible!!!! Think that my car, can't figure where the coolant is going!!! Thnx so much slingeratkins@gmail.com
da
Sounds like a intake leak or head gasket leak. Any coolant getting into the engine will cause a knocking sound , because water can't compress like air does.
da
Intake plenums are bad about leaking on these model cars.
da
Insofar as your leak goes obviously check your hoses for loose clamps any hoses that are dried out/cracking if they aren't leaking now they soon will be and the radiator. One thing many people overlook when looking for the source of coolant leaks is the water pump. It has a weep hole and when the pump bearings are shot it will begin to leak to let people know to look for a problem. If you have looked and looked and not found the leak. It is probably from the water pump. It starts out dripping slowly as the seal wears from the play in bearing's movement. Until the pump is really ready to go it only drips out when the engine is running.
You have not given much to go on to reasonably ascertain what would cause the sound you mention. Does it happen when you are stopped and the engine is idling? When stopped and pressing on the gas does it increase, slow down or stop? Have you had exhaust work done lately? Many times people don't run the pipes properly and they will thump against something as you describe. I would check your engine and motor mounts if one of them has been compromised it can give the sound you describe while the car is idling. If it only happens when you are going down the road everything I've mentioned so far and a whole lot more could be causing it. From what I have said, oldturkey03 stated and your own experience it is going to be somewhat hit and miss diagnosing the cause(s). If it is coming from the motor, a sensor is more than likely picking it up and in part defining the cause. I would suggest hooking it up to a diagnostic scan tester to help determine the cause. A number of people are not aware of this but many auto parts stores, including AutoZone, offer free diagnostic hook-ups. I would call around to find an auto parts store that does the free diagnostic scan on your car's computer. While they have it hooked up casually ask them about the noise and possible causes. Most of the counter people have a fair amount of experience working on cars and may very well know the cause. This is not a direct solution to the problem. But, it is kind of hard not being able to hear the noise or knowing when it is happening to give you any reliable advice besides take it to someone that can hear it and determine when it is happening. While this is not a direct solution to your problem it is the most economical and feasible one I can think of.
NOTE: The computer diagnostic scanners that the auto parts store will hook up for free is the same one(s) used by many mechanics who will charge you for the service.
Punteggio 7
2 Commenti:
Thank you.!!!
da
Wow you're really wrong about the guys behind the counter half of them don't know what you're doing believe me I know I'm a shade tree mechanic and no more than they do I can sit there and argue with them all day long
da
Sue. I'm going to give my two cents worth because you're getting a little Miss information here from too many different directions. the vehicle in question has a long history and track record the knock noise you're describing. General Motors changed their formulation of coolant to something called dex-cool. now there was a lot of struggle within GM with dex-cool and it took them a good 15 years to get it right. what you're describing sounds to me like an example of that struggle. the Dexcool tends to be very corrosive to the intake manifold gaskets and the silicon used to seal them. coupled with General Motors recommendations of not changing the coolant for a hundred thousand miles to 150,000 miles leftmost General Motors cars being severely neglected in the cooling system department. estimate of time between service intervals was way too far. by your initial description and it going off your initial description only I personally would wager that your problem is with the dex-cool and the intake manifold gasket. the reason I say that is I live in a very mild climate it isn't so hard on cooling systems and as a 20-year ASE Master automotive tech I have done hundreds of these darn things. it seems like more than 80% of these motors off fail for the same reason. that reason is contamination of coolant into the oiling system. if you seem to be losing coolant and you don't know where it's going mostly cuz its leaking internally in the engine. even a very small amount mixed with the oil will strip the rod and main bearings and rocker arm shafts of the protective coating. if you are hearing the noise 9 times outta 10 the problem is already too large to deal with anybody needs a replacement. it is my experience once you start having that noise problem the problem is systemic throughout the system. now if its in the upper valvetrain that you're hearing the noise first in the rocker shafts. Doyle that's in the rocker shaft first started in the oil pan and the crankshaft and the rod bearings main bearings and work is way up through the motor in the passageways up to the top where it then return through our passageways back to the bottom of the engine. so if there's noise up there there's contamination likely up there if there contamination up there it's likely the contamination is systemic. you can get away with doing about job placing rocker shaft that kind of stuff but its only going to be a bandaid fix. sooner you can get the car or better yet have it towed to a prare the better I mean even if it's sitting there overnight not running that mix of coolant is catching away at theI soon are the better I mean even if it's sitting there overnight not running that mix of coolant is etching away at the bearings. so I stress the sooner the better. I have seen him and survived 4. Time afterwards but lately you've taken a good chunk off into the life of the engine. so even if the outcome is good give me want to consider trading it in. sorry for the bad news but I've seen many many many of these. Like the others have said there are other possibilities they just aren't real pattern failures on that particular engine the coolant and oil mix through the intake manifold is definitely the highest. I'm by your description I would almost bet money that that's the problem. but being as I am a mechanic and not a gambler do not Gamble other people's money nor do I gamble with mine. I get the facts and make an informed decision. that is the course of action I recommend for you. Dollar General Motors dealership will know this problem and know the vehicle well if you have a trusted mechanic by all means bring it to him or her. if you do not the General Motors dealer is a good place to bring it to be checked out they will be able to give you a good diagnosis. I hope the best. good luck Sue
Punteggio 3
1 Commento:
I am also a ASE certified Mechanic. This thread is old but this is just to help clarify. The intakes do leak because of dex-cool. This applies to ALL GM 3.1, 3.3, 3.4, 3.5 liter engines that use dex-cool. I have also in my career replaced MANY of the lower intake manifold gaskets on these. Make sure to get the updated gasket kit. Be carful of you overheat the engine just once you can damage the head gaskets. One other note is on a rare instance some times the prematurely break a crank bearing causing this and also very dirty oil will effect the VVT solenoid causing noise. You can run a QT of tranny fluid in the crankcase for about 15b minutes before changing the oil. The detergents will clean the crankcase and oiling ports and gallies. The crank bearing fix well I'm sure you probably have a good idea what that is going to take, a rebuild or new motor, take your pick.
da
Bad bearing, lifter,push rod ,flywheel, piston skirt, timing ,piston,distributor,number of things really
Punteggio 0
1 Commento:
What is that clamp that is screws to the push rods
da
Maybe your EGR valve is stuck closed? Do you notice any loss of power, hesitation or lack of acceleration at all?
Punteggio 0
1 Commento:
Yes all of the above
da
My answer is pull a plug passenger side front or rear these engines are bad about leaking head gaskets, water in cylinder will usually show the problem, I have replaced many.
Punteggio 0
check your radiator cap
Punteggio 0
check your egr valve its gunked up.
Punteggio 0
Aggiungi la tua risposta
Sue sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 70
Tutti i Tempi: 415,878
