How to replace the clutch on a 01?
need to know how to replace the clutch on a 01 chevy cavalier
Questa è una buona domanda?
Have you ever replaced a clutch ? Do you have access to tools including at very least a 2 ton floor jack ? do you have access to a cement floor . This is a job you will need at least 7 hours for . If your not experienced it can be overwhelming . That being said let me know what level of mechanical skill you have and what part of the repair your having difficulty with . Check on you tube for videos anything from 1995 -2005 will do as they are all the same basic configuration in the Cavalier or Sunfire
ordiwaymelissa that is a tall order for this forum. Lots of steps involved with that. Here is what the manual says about the removal CLUTCH.pdf. I'd definitely recommend getting a service manual either from a library or purchasing one.
Excellent manual Mike .The master strikes again ;-)
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 2,110
