Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
Stuck on Support screen
Hi,
My iPhone5 is stuck on the support.apple.com/iphone/restore screen when I plug it into the computer. I tried the hard reset ( pushing the Home button and the power button at the same time), then the screen goes black, and nothing happens until I let go of the buttons, and then it goes back to the apple logo support screen. Any help with this would be greatly appreciated.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
Does iTunes detect it?
da
I dont believe so because when i attach something like my Shuffle, it automatically detects it.
da
Aggiungi un commento
2 Risposte
Try putting it in dfu mode (DFU_ModeDFU MODE), connect it to your computer and restore. Your computer should detect it or try restarting all of the apple processes in task manager and reloading iTunes. Hope this helps.
Punteggio 0
2 Commenti:
Hi9,
I tried to put it in DFU mode, but it seems that it will only power up when it is attached to my computer, and not any other time
da
Yes, when you are in dfu mode it stays in dfu mode and shows a black screen, even when connected or not connected to a computer. Did you try restoring?
da
I think the problem maybe hardware related have you done any hardware repairs to the device?
Punteggio 0
Aggiungi la tua risposta
bigdot11 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 94
