Salta al contenuto principale
A compact, desktop thermal printer designed exclusively for parcel/post labeling released in 2010 by Zebra Technologies.
2 Domande Visualizza tutte
ink is smearing on labels
I am using the zp 505 printer for labels. The labels keep coming out with the ink smeared. I have cleaned it multiple times. What could be causing the smearing of the ink on the labels ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
The printer doesn't use ink, the paper that goes through it reacts to the temperature of the print head, a bit like a till receipt.
You might need to clean the print head, or it could be a faulty print head
Punteggio 0
I had the same issue. I used a alcohol wipe clean the print head. I let it dry before use and it worked find without any smearing issues.
Punteggio 0
Aggiungi la tua risposta
Lilach Bluevise sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,255
