Salta al contenuto principale
The 2004-2008 F-150 truck was introduced in January 2003 for the 2004 model year as the redesigned eleventh generation of the F-150 lineup.
engine knocks when hot when going slowly
engine knocks bad when hot only when trying to go slow like a drive through. put in neutral and give a small rev and it stops.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
First things first, get it scanned and see what codes come up.
Knocking implies bearings, usually big ends and it doesn't usually go away with a rev.
But what you call knocking I may call pinging. So are you saying it sounds like an old diesel with that death rattle they have in the top end. Or are you saying it has a dull thudding noise coming from the bottom end?
Punteggio 0
Aggiungi la tua risposta
Robert Carter-Wood sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 94
