Salta al contenuto principale
Guide per la versione Wi-Fi dell'iPad Mini 2. Annunciato il 22 ottobre e introdotto il 12 novembre 2013. L'iPad mini 2, noto anche come iPad mini con Retina Display, ha tutti i pixel dell'iPad Air in un più piccolo fattore di forma da 7,9"
220 Domande Visualizza tutte
LCD backlight not working after front panel replacement.
Hi.
Tonight I replaced the front panel of my brothers iPad mini 2, ensuring to disconnect the battery before unplugging the LCD and Front panel, yet upon reassembly, the LCD backlight is no longer working. I am aware that unplugging the LCD with the battery connected often blows the backlight fuse, but I made sure to unplug the battery first. Could any of you advise what could have gone wrong?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
We have a backlight troubleshooting guide.
see if this is any use for you: iPhone Backlight Not Working
Punteggio 0
Any chance you damaged the LCD removing it?
Punteggio 0
1 Commento:
I doubt it, I shone a light into the LCD and there is an image, just no backlight
da
You may have already done this but unplug, clean and replug in all the connectors in. Happened to me before on iPhone, dust or something must've got into the connector. If that doesn't work I'm not sure what to suggest.
Punteggio 0
Aggiungi la tua risposta
Daniel Bowden sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 54
