Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
1199 Domande Visualizza tutte
Can you remove a broken fire wire stuck in an port
I need help
I used a friends aftermarket charging plug and when i attempted to pull it out it the tip snapped and is now stuck inside my firewire port..
Took it to apple and they wouldnt even open it up
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Sharp straight tweezers can get the part out without opening it.
Can you post a picture of it here?
Punteggio 0
1 Commento:
It didn’t work
Far to jammed inside
da
Get a cotton ear swab (the smallest the better). Get superglue and try to stick the tip of the cotton to the end of the connector. DO NOT USE TOO MUCH OR GET IT ON THE SIDES this will make it even worse. Leave it there until it is fully dry (like 30 minutes JUST to be safe) and try pulling it then. You can also use a toothpick and some cotton on the tip.
Punteggio 0
Aggiungi la tua risposta
yeageraaron sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 92
