Why is my screen nearly black after a drop?
I dropped my tablet on the parking lot from about waist high. It had a pretty good case on it. At first wouldn't turn on but after holding both the home button and power button it came on. The only problem is the screen is dark and you can barely see the apps on it. The brightness button is all the way up. Any suggestions?
Questa è una buona domanda?
1 Commento
Hi Sharon,
It sounds like the backlight, or whatever is powering the backlight, may not be functioning. You can check to see if a display cable came loose by following instructions to get to the cable and finally checking the cables here.
If the connectors are in place, then it can be the display assembly or the logic board (where the connectors are).
da Arthur Shi
