Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
Why is my new battery at 76% capacity on CoconutBattery?
Just changed my battery a few days ago and it definitely lasts longer than the previous battery I'd had for over 3 years. However, coconut battery says it's only at 76% capacity which is only a little better than what it said with my old battery. I know CoconutBattery is not precise but it does seem to be pretty accurate for my computer and iPad. I'd checked a couple of times with the new battery and it is consistently less than it should be.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Does it tell you the number of cycles the battery has had?
da
Yes, it's only had 3 cycles. I also made sure to discharge the phone past 10% and recharge uninterrupted to 100% after I installed the battery. And did the hard reset after installing.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
There isn't a precision issue with coconutBattery or any other utility that reports battery data. These tools aren't interpreting anything, they are just reporting what the battery is telling them. So if you see 76% and your skeptical, try a different utility such as 3uTools (Windows) or iMazing (Mac) to see if they are consistent.
As for such a low reading...batteries aren't solid state devices, there more of a chemistry experiment :>). Not all batteries are created equal and I have even seen batteries that report greater than 100% capacity. You may have a bad battery or one that has been sitting on the shelf for a long time. Do a few full discharge/recharge cycles to see if it gets better or not. Otherwise, return it to the vendor.
Punteggio 3
1 Commento:
I tried draining the phone and hard resetting again, and then charging to 100%. Coconut battery now says 91.9% design capacity. Not perfect, but the battery isn't defective at least. I guess it just needed a few more cycles to calibrate. Thanks for your answer! :)
da
I had the same issue . I would not rely on CoconutsBattery I had totally different results with iMazing and iOS utility. I have uninstalled Coconut Battery from my Mac too.
Punteggio 0
Aggiungi la tua risposta
SAA sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 26
Tutti i Tempi: 4,396
