Salta al contenuto principale
Una collezione di guide e supporto per l'aiuto alla riparazione di lavatrici.
20 Domande Visualizza tutte
Lg wd80130f drain pump wiring
i was replacing drain pump on my front load washer and i forgot how it was wired.
it has two wire black and brown. the pump has label L and N. i remembered the wiring in my mind before disconnecting it but now i am confused whether to connect brown to N and black to L or is it supposed to be other way around?
Questa è una buona domanda?
Punteggio 1
7 Commenti
Did you ever find out the answer? My husband is stuck in the same situation.
da
I did, but unfortunately i forgot how it was.i think brown will go to L and Black will got to N
da
Thank you! He is almost finished with it. Fingers crossed lol
da
L (Live wire) = Brown/Red colour)
N (Nuetral) = Black/Blue colour
da
What if they’re both red!? One is a double wire and one is a single but they’re both red so I don’t know which one
da
Mostra altri 2 commenti
Aggiungi un commento
3 Risposte
Soluzione Prescelta
manubali811 @amy3782 just for completion sake, here is the wiring diagram for your washer
and here is where to hook it up to
Punteggio 4
1 Commento:
So the Black is Live and Brown Neutral, very confusing
da
That model number did not work. However here are a couple of video on replacing the drain pump on an LG machine:
https://www.repairclinic.com/PartDetail/...
Punteggio 2
where is L&N? Pls help me
Punteggio 0
Aggiungi la tua risposta
manubali811 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 18
Ultimi 7 Giorni: 91
Ultimi 30 Giorni: 421
Tutti i Tempi: 35,710
