Salta al contenuto principale
Lanciato il 24 ottobre 2011 / processori quad-core Intel Core i7 da 2,2, 2,4 o 2,5 GHz
405 Domande Visualizza tutte
optical drive not detected after ssd install and logicboard install
The logic board failed in my macbook pro 2011 late model. I thought it was the HD so I replaced it with an SSD. Then realizing that the logic board was bad, I replaced that and reinstalled the OS.
Now, I cannot use the optic drive. There is no indication that it exists on the computer. I try to put a disk in and it will not receive, make noise......nothing.
I have tried resetting the PRAM and SMC. Nothing.
Please advise as to what I need to do. I need the cd/dvd rom for work related purposes.
Thank you in advance!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Sometimes its the simplest thing are you sure you reconnected the drive cable? Review Step7 here: MacBook Pro 15" Unibody Late 2011 Optical Drive Replacement. If it appears connected take a good magnifier and inspect the socket and cable contacts one or two could be bent.
Punteggio 1
Aggiungi la tua risposta
hot98tj sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 31
