Salta al contenuto principale
Sesto modello di iPhone Apple, annunciato il 12 settembre 2012. La riparazione si fa in modo simile alle precedenti versioni di iPhone e richiede cacciaviti e strumenti di apertura. Disponibile con tecnologia GSM o CDMA, con 16, 32, o 64 GB, nero o bianco.
2522 Domande Visualizza tutte
Testing with different batteries
I have an iP5 not charging at all. I wanted to try using the battery from one of my other broke iPhones to see if its the batter or the charging circuit. I don't to completely install the battery, just plug it into the iP5 and see if it charges. Basically, does any other iPhone have the same plug as the iP5?
Or is there some other way to test the iP5? I have cleaned the charging port and contacts. When I plug it in (various combos of chargers and cords) I get the white outlined battery with the red lines at the bottom for 10 seconds. I leave it plugged in and nothing happens. If I move the cord a little I get the lightning bolt and charging cable icon. indicating that the cord has actually came off the charging contacts.
I was planning on ordering a battery anyway, I just wanted to trouble shoot a little more to see if I need to order anything else.
...Thanks Ralph
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
If moving the cord a little makes it charge, you're problem may be with the charge port. It's not difficult to replace. I would order it at the same time as the battery as those are the two most common charging failure points. If that doesn't solve the issue, then you likely have an issue with the charge circuit on the logic board, which requires a micro-soldering repair and is not DIY.
The iPhone 5 battery FPC connector is unique.
Punteggio 2
Aggiungi la tua risposta
Ralph Goldacker sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 40
