Salta al contenuto principale
Rilasciato il 19 settembre 2014, è la versione con schermo più grande (5.5") dell'iPhone 6.
1525 Domande Visualizza tutte
New display causing white flickering at top of screen
Hi,
I am replacing the display assembly on an iphone 6 plus. Everything works as normal however at startup the screen would often flicker and sometimes be unresponsive to touch. To be more accurate the flickering was a white lineor band that would rise and fall from the top of the screen and the display would become unresponsive or delayed..
The top flex cable connector to me feels loose compared to the origional.
Thx.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I would be sure this is a problem with the touch ic , not the screen .It is commonly known as touch disease. try lifting screen up while still on and connected and putting a fair amount of pressure on the main board (at the black area on shield below the screen connectors )with your thumb and see if the touchscreen responds while pressure is on.
if so then afraid you would need to have the touch ic replaced . It is expensive and requires micro soldering skill. Best left to professionals that have carried out this particular repair before .
Punteggio 3
3 Commenti:
Totally agree.
da
I should have mentioned when I put the original screen back on the problem goes away.
da
You need to try another screen just in case. Sounds like a defective screen.
da
Aggiungi la tua risposta
David sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 212
