Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
iPhone 6 Screw Size Diagram
I do not reassembly old phone. I have ordered each part one by one. So now I have screws but I do not know the right place for them. I want to assembly new iPhone 6. Does someone knows the right size for every single screw that goes in iPhone 6?
Questa è una buona domanda?
Punteggio 6
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It will be much more efficient if you go through the necessary guides here on iFixit as the screws are well laid out and identified. Jessa's videos are great but her goal isn't to show where the screws go :>). Ideally, you will need a caliper (a digital one is easier to use) to measure the screws and place them in the right spot. Be very careful especially around the screen retaining bracket.
Punteggio 5
1 Commento:
Thanks for the answer :D This way it will be much easier from me. From this guides I can find every size of needed screw. I hope that this will be successful project :D
da
Watch ipadrehab videos on youtube, and you will see all the screws.
Punteggio 0
1 Commento:
Do you know which one? They have a lot of videos and I couldn't find appropriate.
da
Aggiungi la tua risposta
Stefan Filipovski sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 11,281
