Salta al contenuto principale
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Domande Visualizza tutte
Display wont sleep when lid is closed?
I've tried the SMC and pRAM instructions on the apple site. I recently replaced the DC-in board 2 days ago, and now the battery indicator lights and status indicator light wont light up, and the laptop wont sleep when I close the lid. Any ideas?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The most likely problem with your MacBook not going to sleep is the reed switch. The reed switch is located in the upper case near the right border of the case on the IR sensor ribbon cable (it sits right under the plastic retaining block that's embedded in the hard drive cable).
The components in question can be seen in step 30 of the A1278 upper case repair guide:
MacBook Unibody Model A1278 Upper Case Replacement
More information here:
Sleep sensor and on/off led doesn't work?
Punteggio 0
Aggiungi la tua risposta
Helldogg One sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,027
