Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Replacing motherboard in iPhone 6
Hi, I recently screwed up my motherboard on the iPhone 6 I was wondering if I could buy a replacement board on eBay for like 5$ and fix on all the parts ie storage cpu etc. And use that board in exchange?
Thanks for the help.
Questa è una buona domanda?
Punteggio 1
1 Commento
What exactly did you screw up?
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
you can, but you need to buy a tool from Rewa technology to format and register a serial number to your internal storage. they have a video here: https://www.youtube.com/watch?v=v5WDDZqh...
its for a 6s but its the same process.
It is very expensive for the tool and very easy to break things, so it may be better to buy a working motherboard.
Punteggio 1
Hallo, this board what you find on ebay is blank board.... like dummy.... is only board without all chips etc.... send me the link.... i see too much on aliexpress this board for 4-12dollar... all dummy.
Punteggio 1
Can you microsolder? This is a lengthy process. What exactly did you “mess” up on the board? If you need data there are other avenues depending on what is wrong.
Punteggio 0
Aggiungi la tua risposta
Chao bu guay sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 146
