Salta al contenuto principale
Modello fine 2011, A1278 / processore i5 2,4 GHz o i7 2,8 GHz
591 Domande Visualizza tutte
Left shift key doesn't work
my left 'shift' key stopped working, and it is a nightmare because I use it allot.
I followed all the basic recommendations of previous similar questions:
system preferences>accessibility>keyboard/mouse trackpad as well as the dictation & speech are all in check (no special keys, no slow keys etc).
Opened the keyboard viewer, and the 'shift' is defined properly, when i press the virtual key it responds but the one on the keyboard doesn't (the right one does work).
I pulled out the key and the inside looks intact, with a white silicone thing in the middle and two white frames that hold the key are in place.
Had a little water incident near the computer, but I don't think that any water got to the computer or the keyboard.
Is this an issue of contacts or something? Anyone know how to save it?
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Can't really save a liquid damaged keyboard ;-{ Once its damaged you'll need to replace it.
Now there's two ways:
The easier is to just replace the uppercase. Still quite a bit of work.
The harder is to get a replacement keyboard and replace the keyboard alone after you've got the uppercase free from all of the other parts.
Here's the IFIXIT guide to replace the upper case: MacBook Pro 13" Unibody Late 2011 Upper Case Replacement and here's the part: MacBook Pro 13" Unibody (Early 2011-Mid 2012) Upper Case.
You'll need to follow this same guide then follow this YouTube: 2011 Macbook Pro 15" A1286 Keyboard Replacement
Immagine MacBook Pro 13" Unibody (Early 2011-Mid 2012) Upper Case
Prodotto
$39.99
Punteggio 1
Aggiungi la tua risposta
Lee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 4,918
