Salta al contenuto principale
Gateway makes quality notebooks, laptops, and netbooks. Owned by Acer Group.
220 Domande Visualizza tutte
So SSD upgrade in gateway.
Some reason my last post was deleted.
I’ve got a crucial mx500 500GB SSD for my grandpas gateway NV55C laptop. I’ve also upgraded the CPU to a i5 and ram to 8GB. I am running into some problems transferring the old files to the new SSD. On the old drive I click my user and it says “administration permissions” and if I click continue it goes but then stops at the end.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Try doing it while having the computer booted in safe mode.
Use advanced startup options to boot safe mode:
https://www.tenforums.com/tutorials/2294...
This may also help you too:
https://www.tenforums.com/tutorials/3841...
Punteggio 2
Better yet, if you are comfortable with Linux, use the live USB of sysreccd or Ubuntu.
Use the command 'rsync -rv --progress <source> <destination>'
Punteggio 2
2 Commenti:
I think I’ve got it now. It finally opened it up! Last night I started the transfer and I’m going to check it soon. If it transferred correctly all 64GB should be transferred. That’s all I need to do.
I did a clean install of Windows 10 because it had windows 7 and the updates were going crazy.
da
If you transferred into an account folder (i.e. user\documents), and not a root folder, you will likely have a permissions problem, and not see the files on the new computer.
da
Aggiungi la tua risposta
Padraic Hoselton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 145
