Salta al contenuto principale
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
133 Domande Visualizza tutte
How To Replace Just Glass on ZTE Zmax Pro Z982
so i shattered my phone screen an ordered just the glass replacement someone help or do i have to order the screen and digitizer??
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi,
If you haven’t got equipment to do glass only refurbishment, it is highly recommended that you order a full display, as most phones these days have the display and glass/digitiser fused. :-)
Punteggio 1
The glass and the LCD display are two different parts on this phone and can be replaced separately. The digitizer is built into the LCD, so if you only cracked the glass in front don’t order the $40+ dollar full LCD assembly. You can order just the glass on Amazon. A warning, though, replacing this can be difficult. A good option would be to look up some videos on Youtube on how to replace the glass and decide from there whether or not you want to go through the trouble, otherwise most cell phone repair stores will still work with you if you bring in your own replacement parts, it will save you a few bucks doing it this way.
Punteggio 0
Aggiungi la tua risposta
Kali Killa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,904
