Salta al contenuto principale
Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
How to collapse piston in rear caliper on 1992 civic
i am trying to push the piston in the caliper in with a c clamp to change the pads. it will not budge. should it push in or am i missing something. both sides are the same. i removed the resevoir lid and even opened the bleeder screw to no results. thanks for any help.
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
It takes a special tool. The piston needs to twist in. You should be able to barrow the tool from AutoZone for a deposet or you can buy 1. From this video I see you can also use a chissel like a screw driver to screw it back in.
Punteggio 3
1 Commento:
thank you so much. i kept looking at the slots in the piston thinking i was probably supposed to turn it. round 2 coming up.
da
a automotive file works GREAT you can get them anywhere for like $1.00
Punteggio 0
Aggiungi la tua risposta
rich sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,222
