Salta al contenuto principale
Modello fine 2011, A1278 / processore i5 2,4 GHz o i7 2,8 GHz
591 Domande Visualizza tutte
Battery Failure with new battery MacBook Pro 2011
Hi! I just changed the battery and installed CoconutBattery.
I was in the middle of calibrating (at least, I think it was calibrating: it was the process of fully charging, then let it fully discharge, and charge it again). As soon as I unplugged the power, the charge jumped from 100% to 80% and Coconut shows Battery failure.
Did I got a faulty battery? Or is there something I could do like resetting SMC?
(I apologize for my bad English: it's not my native language and I guess I made a lot of awful mistakes :))
Questa è una buona domanda?
Punteggio 0
6 Commenti
And now it automatically powered on as soon as I plugged in the power. it is not normal, I guess?
da
What was happening with the old battery? Would you now run Coconut with the mag-safe plugging in and post a photo of that.
da
Unfortunately coconutbattery trial expired so I cannot see the advanced info anymore. The free version only shows me this
https://i.imgur.com/fRHL0fA.png
and this is the info in About this Mac (I don't know if it may be useful)
https://i.imgur.com/iqpWHgO.png
Btw I was using the Mac and it powered off at about 60% charge. Afterwards I tried to power it on but I couldn't get it past the apple logo. Is this normal? With my old battery, once it shut off because of the charge I couldn't even get it to seem to start.
da
your latest update is when using the old battery or the new one?
da
When using the old one
da
Mostra 1 altro commento
Aggiungi un commento
1 Risposta
Risposta Più Utile
Once in a while I get this issue with new batteries. Try at least 5 cycles of full charge and discharge and see whether the issue will go away.
Punteggio 1
1 Commento:
Thank you. I was beginning to think it would be better to put in the old battery, but I'll try to wait.
Also, it takes a lot to fully charged, compared to the old one.
da
Aggiungi la tua risposta
ghilo89 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 493
