Coolant leak Cruze 2013
Coolant leaking by battery but not from the reservoir in a Chevy Cruze 2013 what's the most likely cause
Questa è una buona domanda?
Punteggio
0
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 351
Get your car scanned and see if any codes relating to coolant temp sensors or thermostats come up. Also, while the engine is off lift the bonnet/hood and with a strong light look all over your engine for coolant trails. If you find one try and trace it back to it's source. Possible it is coming from a faulty pipe or water pump.
da sm_vulkus
