Salta al contenuto principale
Display LCD widescreen da 4.3’’ con processore da 333 MHz. Numero di modello PSP98510. Riparare questo dispositivo richiede cacciaviti e strumenti per fare leva.
PSP 2000 Battery not working correctly
I bought a brand new PSP 2000/3000 battery off amazon a while ago since my other one seemed to have died. It worked when I put it in the for the first time, but after that, the battery would disconnect and reconnect very quickly (at least according to the XMB and P Tester) The system would still work fine plugged in without the battery, but if I have the battery inserted while plugged in, the PSP would assume the battery is full after a couple of minutes and shut down, requiring me to remove the battery and the power adapter to boot back up.
I've also tried different adapters, 2 USB/Charging cables and an official Sony charger.
Can somebody help?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I would say return it to Amazon as defective and buy from another seller there.
Alternatively, aliexpress has reviews on their items as well.
Punteggio 0
Aggiungi la tua risposta
Jobel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 344
