Why does my camera shut off seconds after starting to record a video?
With a fresh battery and fresh SD card the camera will shut off moments after starting to record a video and say "charge the battery" I turn it back on and the battery is full.
This is such a frustrating issue and I dont want to spend hundreds to send it to cannon when the fix might be simple.
Questa è una buona domanda?
When you say fresh battery, do you mean you just charged it or did you just buy a new battery? Do you have a 2nd battery to work with?
da S W
All the batteries I have do photos fine, just not videos
da RichManSCTV0
Hi Rich,
SW asked if you were using a new battery. The batts you have may have internal resistance. They can give you enough current flow for a split second for a still pic but not enough continuous flow for a video. Try a new battery. If no success, it means there is a resistance inside the camera. I can't help you there.
da tonydet
Before taking any drastic or expensive action, check out all the connections and wiring from the battery to the PCB including battery contacts. A small amount of corrosion can cause a big resistance in very small components. Corrosion on the PCB can short between 2 components. You may need a magnifying glass to see it. Good luck.
da tonydet
Connection is fine, seems to be a common hardware error that happens to pop up right outside warranty range UGH
da RichManSCTV0
