Salta al contenuto principale
Model M7572 / 400 or 500 MHz G3 processor
45 Domande Visualizza tutte
Why is there just a grey screen?
When I power on, the screen stays grey like its loading the software but, I don't hear the harddrive spinning. The screen just stays grey. I have replaced the harddrive but still same problem. What else could it be?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Try starting up from your system installation disk by restarting with the disk inserted and holding down the "C" key. Format the new drive and install a system.
Punteggio 3
9 Commenti:
The long tone was from you holding down the start button to long. Are you saying it will not start up from the system installation disk? If that is the case, disconnect the hard drive and try starting from the CD and let me know your results. Reseat your RAM while you're at it.
da
With the hard drive in and the CD in, start up holding down the "C" key. If it starts up use Disk Utilities to try to repair the hard drive. If it won't start, remove he hard drive and try starting from the CD again. If it starts then we can look at replacing the ATA/IDE 2.5" hard drive.
da
UPDATE you unaccepted the answer. What's wrong?
da
Great, progress- Reseated the RAM and removed the hard drive and it started from the disc. Turned it off and put the hard drive back but second start up resulted in the original problem. Is my hard drive bad?
Thank you for all your time and efforts. You are a God send. - Gabriel C.
da
Hello, I replaced the hard drive with a brand new one.
When I hold down the c button the screen remains with the apple logo on a grey screen and will not start the installation process. When I took out the hard drive it started from the cd - no problem. Any advice at this point. Thank you
da
Mostra altri 4 commenti
Hello, the system installation disk is a retail system disk, and the new hard drive is
Condition: NEW: Factory Sealed!
Rotational Speed (RPM): 5400
Capacity: 100GB
Drive Type: Enhanced IDE (ATA-6 or PATA)
Buffer Size: 8MB
Product Life: 5 years or 20,000 Power-On Hours
Form Factor: 2.5" for Notebook
Dimensions (mm): 9.5 (H) by 70 (W) by 100 (D)
Please Advise. Thank you
Punteggio 0
1 Commento:
The system is Mac osx 10.4.6
da
Aggiungi la tua risposta
juice sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 628
