Salta al contenuto principale
Numero modello A1707. Rilasciato a giugno 2017, questo MacBook Pro adotta processori Kaby Lake fino a Intel Core i7 quad core da 2,8 GHz con Turbo boost fino a 3,8 GHz.
Not all of the trackpad is clickable
So ive noticed on my personal machine that i cannot click anywhere on the edge of the trackpad i have to click at least 1cm in from the trackpad in order for the force touch to even click, for example i cant even right or left click right in the corner this doesn't happen on the 13 inch im just wondering if this is normal as most of the time im using a bluetooth mouse.
Questa è una buona domanda?
Punteggio 3
4 Commenti
You may need to visit a store which has one on display to verify. For some reason I think thats right the click area is not to the edge.
Apple is pushing to the touch mediphor like the newer iPhones. So now you press and hold to gain access to the right click menu.
da
The MacBook Pro trackpad is not all clickable I have one. 80% trackpad is clickable.
da
ah well I'm glad I'm not the only one I hope this might be fixed at some point now that I've noticed it, its really annoying
da
@danj it happens with both left and right I just stated right as thats most difficult as you naturally click in the bottom right
da
Aggiungi un commento
3 Risposte
Risposta più utile
Check with Apple to see if this is covered under their new program.
Keyboard Service Program for MacBook and MacBook Pro
https://www.apple.com/support/keyboard-s...
Punteggio 3
2 Commenti:
i popped it into them today, they refused to do anything, i checked all the devices in the store and around 7 of them had the same issue however some of them didn't, at first i thought it was all devices.
da
Contact Apple directly at 1-800 MYAPPLE
da
I had the same problem.
Apple actually changed my trackpad/keyboard 3 times in a row before realising they couldn't do anything.
They then understood it was a broader problem affecting all new 15'macbook pro.
They explained to me that the haptic feedback does not cover the whole area of the trackpad. There is no fix.
Punteggio 2
Compared to the ones I've seen in store, the whole trackpad should be clickable? Even if half of your finger is off one side, it should still be able to be clicked? I would definitely try and take it into a store if possible and compare/get them to repair it for you.
Punteggio 1
1 Commento:
It appears on all or most of the 15 inches ive had the trackpad replaced twice and a new machine they say theres nothing they can do and its normal which it clearly isnt
da
Aggiungi la tua risposta
lewis Barker sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 16
Tutti i Tempi: 2,005
