Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3530 Domande Visualizza tutte
iPhone 5s No Service/Line Searching iTunes ERROR -1
Hye I got n IPhone 5s sent in to me for repair. The customer claim that his IPhone having a No Service issue, and after restore iTunes got an error -1.
So my question is should I reball the BB CPU first ? After reball, what should I do if the problem not solved ? Cuz I read some thread on the internet saying that error -1 is not only because of BB CPU, some of them said its because of BB PMIC. How should I know which one is the right solution ??
Questa è una buona domanda?
Punteggio 1
5 Commenti:
do you get the imei when you dial *#06#
da
How can I get the imei number if the phone are stuck in itunes logo
da
it doesnt say in your question that its stuck on connect to itunes, try using 3utools to kick it off recovery or if that doesnt work try flashing the ipsw
da
lol. this is not a software issue, this is hardware bro. im pretty sure its hardware
da
If it's stuck in a iTunes recovery logo loop at least try to exit recovery mode via 3uTools.
It probably can still boot up if it didn't start flashing the firmware on there yet.
Then you can check what he said in the comments.
da
Aggiungi un commento
1 Risposta
Error -1 may be caused by connection problem, network connection or hardware issue.
About hardware problem, probably check the baseband.
Punteggio 0
Aggiungi la tua risposta
Azim WHITE sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 581
