Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
Aftermath of water damage on iPhone se
so there was water marks on screen so I closed my phone and put it into rice then I opened it and saw this top right edge of screen looks like this can I fix it anyhow without any replacement
1 day later it looks like this
Also what is weird to me that it only been in water for 4 or 5 seconds I pulled it over immediately and dried it with napkin but it still took this much water at least in screen
well those white strikes are gone instead there are water stains now and phone still functions perfectly and water control stickers are white not red phone only been in water for 4-5 seconds why did screen take so much water this is model A1723 by the way
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
In your case, the damage seems to be limited to the screen. With water damage though, you should decontaminate the logic board before doing anything else, otherwise there will be latent issues down the road.
You could replace the screen (that's the only option here) by following this guide.
Punteggio 2
3 Commenti:
so is screen damaged for sure and can you give me the details
da
Just click on the guide provided to learn how to replace your screen.
If you want to decontaminate your logic board:
* Open your phone and remove the logic board (follow the guide)
* Inspect the logic board, especially around the connectors and look for corrosion.
* Inspect both sides of the board. Unfortunately, most of the board is covered in shields. That's usually where the damage is occurring.
* Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
* Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
* Rinse in alcohol and repeat.
* Let it air dry for a day.
* Re-assemble and hope for the best.
You should also replace the battery if it has swollen. Resist the temptation to pop it to let the gas out. A compromised Li-ion battery is a fire hazard. If the device appears to power up but behaves erratically, then use a tool like 3uTools to flash the firmware as it may be corrupted.
da
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
da
Aggiungi la tua risposta
Silver Hedgeho sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,440
