Salta al contenuto principale
Faulty sound on earphones and dock
Have a faulty sound on earphones and connected to a dock.
I thought of replacing the earphone jack but i don't think that connected to a dock the problem should mantain. Are they related or is this a logic board fault?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Unfortunately, this is most likely a logic board issue. If the sound is messed up both out of the dock AND out of the headphones, i've found in the past that this indicates a faulty logic board.
Punteggio 0
1 Commento:
100% sure? Not worth a try then?
da
Aggiungi la tua risposta
BOL sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 808
