Salta al contenuto principale
The Dyson V6 Motorhead Vacuum is a lightweight, cordless vacuum. It easily converts for handheld cleaning using a simple dirt bin instead of replaceable trash bags.
Why is the brush roller sticking for v6 vacuum
teeth on lower roll insert that can interfere with teeth on the housing. My brush roll will not turn when re-installed. It installs easily, powers up, spins about 4-5 revolutions, then shuts off power for a second, then comes back on without roller spinning at all. I can see it is the teeth interlocking but don't know how long it makes the first 4 or 5 revs.
Questa è una buona domanda?
Punteggio 2
2 Commenti
Did you find a solution?
da
my roller will not turn on my v6 dyson but a new roller will do i have a problem with the old roller or is the problem with the cogs that turn the roller?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Pull the roller and examine it and see if the cogs are worn. Jere’s how:
Dyson V6 Motorhead Brush Bar Replacement
Punteggio 2
Aggiungi la tua risposta
Ryan Burns sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 4,525
