Salta al contenuto principale
La quinta generazione debuttò a gennaio 2005.
28 Domande Visualizza tutte
Where is my camshaft position sensor located?
I have a 2008 Volkswagen Jetta Wolfsburg Edition 2.0 T. I need to replace my camshaft position sensor but can't find the location. Anyone know where it is located. I've found videos of the position on other years but none of them match mine.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
If you open the hood you take off the airflow engine cover and on the left side by the left headlight there's three fuel lines and it's just behind where the rubber hoses connect to the metal fuel lines there's one bolt that holds it
Punteggio 1
On the CCTA 2.0 TSI the sensor is located on the valve cover directly above the intake manifold. The connector will have three wires and a standard Bosch connector.
Update (11/27/2018)
Connector #2
Punteggio 0
Aggiungi la tua risposta
Brittany Kenney sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 54
Tutti i Tempi: 4,221
