Salta al contenuto principale
Can be identified by Serial Number: 31.2000.2338851 Manufactured by Keurig
20 Domande Visualizza tutte
Keurig K10 Mini brew switch intermittent problem
The brew-switch on my K10-Mini does not always change to flashing red (stays flashing blue) when I push it. Pushing multiple times normally solves the problem, but it is getting worse. The machine is two years old and brews one cup per day on average.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Sounds like you might need to descale your machine. Crap builds up inside the boiler and prevents correct operation. If you have your manual it will describe how it is done.
Otherwise go here
Punteggio 0
Thanks. Could you please explain how scale in the boiler could prevent the heater from switching on.
Punteggio 0
Aggiungi la tua risposta
Mike Webb sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 155
