Boston Acoustic Horizon Solo Volume Control
The volume knob on my Horizon solo just up and quit functioning one day. Everything else still works fine, but I am unable to adjust (or display) the volume. This seems to be a common problem, as far as I can tell, but I have found no solution. I have tried:
Soft reset (did nothing)
Other sites recommended adjusting volume to 00 and then holding down volume control for 10 seconds. I was able to get the volume down to 00 by repeatedly plugging it in and adjusting volume down one notch at a time (I am stuck at level 24...........when I can manage to get it to display volume level)
I cracked open the case to I could attempt to spray the volume knob stem with some tuner-cleaner, but the access to the controls seemed a bit difficult to reach without some sort of guide to tell me what to do (and what NOT to do)
So as it is, I am stuck with a clock radio with excellent sound (If I like volume level 24) and absolutely no volume control. I hate to brick this thing......I can't really afford to replace it right now.
If anyone has a remedy for this situation, I would greatly appreciate any input I can hear.
THANKS!
Questa è una buona domanda?
2 Commenti
My volume is unable to reset by putting on 00 as it jumps to clock setting before 10 seconds reset has elapsed
da Gary Dranch
I am having the exact same problem if you can't move the volume.How are we supposed to get it to 0. To start this supposed reset
da john evans
