Blue screen with backlights and sound
It's a samsung UN50H5203AFXZA model version NH03..
Screen went blue while was on. The sound is on I do have good back lights. Iv replaced the tcon main and power boards. which I ordered of from shopjimmys. I do not see image with flashlight. I also reset with power button.
Questa è una buona domanda?
7 Commenti
Isn't that also called the main board? The tv is a samsung un50h5203afxza version nh03.
da Jodi
I have a Samsung UN50J6200 AFXZA LED tv and same issue. While watching tv, blue screen appeared, audio works fine. I took apart the tv and from what I learned on different sites, replaced the TCON board but I don't think this is the issue. I've tried both the HDMI ports and the Audio and Video jacks with a DVD player and Wii console and audio works perfectly but the screen is just blue. Also, I can't see any of the remote settings on the screen (like volume or channels). Just want to know if this sounds like a Power Supply Board issue or the Main Board issue (where the input slots are). Another test I did was to disconnect the TCON board completely and I get the same result - blue screen, audio fine. There are two ribbons that exit the TCON and connect to another small board on the bottom of the TV. What are these called? I wonder if those would be the issue?? Any help would be great!
da Lisa
It's the backlight. Have the same problem
da Christof Geraerts
I have a samsung model#UN55J6201AF and my tv screen is blue and I don't know what to do about
da Jeffery Ransom
Did you have any luck? I have a Samsung UN60eh6050fxfza, blue screen nothing else. Audio works perfectly, tried av cables as well didn’t change. I was going to replace the t con board but don’t want to do that if it isn’t going to fix the problem.
da Kristen Todd
Mostra altri 2 commenti
