Salta al contenuto principale
Released in 2013, identified by model number: RZ03-0038, Mechanical Gaming Keyboard and product number: RZ03-00381900-R3U1.
10 Domande Visualizza tutte
Water damaged Razer blackwidow Ultimate 2016 down aroow
So a few months ago I spilled some soda on my keyboard. I have contacted razer support team and they said your warranty doesn't cover water damage so I took my keyboard apart and dried it with paper towels then let dry in front of a fan for 2 days and all my keys besides the down arrow key.
I tested my switches with a multi-meter and the switch it self seems fine its sending power but it's not sending input to the computer though so I would like to figure out what I can do to fix my down arrow key
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
i would start by removing the keys, and soak the board in 99% isopropyl, then scrub it with a new toothbrush. this will break away any corrosion, without causing the metals to oxidize. blow dry for a minute, then let sit for 30 minutes. see if that gts you key running. The fact that the switch is working, but the signal wont send means the damage to the trace could be nearly anywhere. finding it would be very difficult.
Punteggio 1
5 Commenti:
Do you mean remove the keycaps or the switches them self
da
keycaps. sorry for the miscommunication.
da
Its alright just wanted to make sure and thanks for the information ill be doing this next weekend when I have time
da
please keep in mind, this is only one possibility.
there is also a likely scenario where the short from the water has fried out a component used to process the signal. cant say without actually trying this first though.
da
Alright thanks for the information
da
Did you ever find a solution to this issue?
Punteggio 0
Aggiungi la tua risposta
Dakota Milam sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 7,506
