Salta al contenuto principale
A1706/ EMC 3071 — Lanciato nel giugno 2017, questo MacBook Pro ha processori Kaby Lake fino a Core i7 da 3,5 GHz con Turbo Boost fino a 4.0 GHz.
276 Domande Visualizza tutte
My touch bar got cracked and is no longer functional
My touch bar got cracked and the display is no longer functional, can someone give me an estimate how much would it cost to get the touch bar display replaced form the  store?
Questa è una buona domanda?
Punteggio 0
1 Commento
have you got a image, how did it become cracked ?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Replacing the touch bar requires a full topcase replacement, and Apple will replace the battery with it. Unfortunately it's pretty expensive. A full topcase assembly comes in (prices from the netherlands) at roughly 500 euros (€ 499,20 to be exact, excluding taxes, which brings it up to 600 euros in the netherlands). Add labour to that to get a full estimate, and you'll end up in the 700 euro range.
Punteggio 1
I would imagine it would be pretty expensive it would most likely be a top case replacement, and not only that I don't if apple will also change the logic board as they are married to the touch i.D sensor which is part of the touch bar.
Punteggio 0
2 Commenti:
Sorry, this is not true. The touch id sensor is a seperate part. It is possible to only replace the touchbar, but this is not for the faint of heart. A new touchbar comes at prices around $50, but to replace it is a nightmare.
da
Sorry, yes i know that, but I was explaining the outcome if he visited an apple store because that is what he asked for.
da
Aggiungi la tua risposta
Saad Ahmad sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,063
