Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
What Happen if removed all the VCC_Main Cap
What happen if removed all the VCC_Main Cap on board (IPhone 6 Plus) ? Does it can cause the temperature increase ?
I have an IPhone 6 Plus sent in to me regarding the Temperature Warning issue. When i look around the board, all the VCC_Main are REMOVED. Before this the IPhone is a water damaged phone.. Any advise ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Temperature error messages are usually related to either defective NTC's (negative thermal coefficient thermistors, such as R1308 etc.) or true excess heat caused by another issue on the logic board. The VCC caps have nothing to do with it. Clearly the previous tech was searching for a shorted component on VCC_MAIN.
Because this phone was water damaged, it must be properly decontaminated first. If that hasn't been done, that should be your first priority. After that, check the thermistors and if those look good, you have to start probing all of the main, PMIC and PMU_RF voltages to get a sense of what is wrong with the phone.
Punteggio 4
3 Commenti:
The thermistors looks good, none of them shorted to ground either. When I put the board on my face there is no heat detected. Would you give me a guideline for probing the PMIC ? Where should I start first ?
da
Start with VCC_MAIN, BATT_VCC & PP5V0_USB. For the PMIC, check the voltage rails it generates:
* The PMIC generates ~15 voltage rails. They are all important (for obvious reasons) but the ones to check first are as follows: PP_CPU, PP_GPU, PP1V8_SDRAM, PP1V2_SDRAM, PP_VAR_SOC, PP0V95_FIXED_SOC, PP3V0_Tristar, PP3V0_NAND, PP1V8_ALWAYS and PP1V0.
* The PMIC also generates, what I would consider secondary, yet still important voltage rails for the following sub-systems: PP3V0_MESA, PP1V8_VA_L19_L67, PP3V0_PROX_ALS, PP3V0_PROX_IRLED, PP3V0_IMU, PP3V3_USB and PP3V3_ACC
da
okay i'll try check the rails. Thnx for the guide line sir. (Y)
da
Questa risposta era destinata originariamente a un'altra domanda.
Hi,according to your description,the NTC thermistor may be broken due to the water damaged before.
Punteggio 0
1 Commento:
ive checked the thermistor, there is no short sign and also the resistor showing normal value
da
iphone 6s temprature error
i change battery
i check the chips also
but it is not heating much
but still showing temprature error
tell me what should i do
Punteggio 0
Aggiungi la tua risposta
Azim WHITE sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 257
